91 Targa Windshield Removal
Old Jan 1, 2010 | 07:09 PM
91C2's Avatar
Default 91 Targa Windshield Removal
Hi! I cut the weather strip on my 911 to remove the glass. I cut it all around and I can now see the edge of the glass all around.
I tried to pusch from the inside but no luck. I am afraid to crack the windshield. Is there glue on the windshield? How do I remove the rear view mirror?
Here is a picture:
Old Jan 2, 2010 | 11:47 AM
They can be a real bugger to push out. Keep cutting the seal and eventually it will get to the point where it will push out. It helps to have a second person helping so you can push it out evenly. Just wait until you get to put it back in. Pulling it is the easy part.
The rear view mirror you will need be be very careful when removing it, it is glued on.
Old Jan 2, 2010 | 12:22 PM
k2we's Avatar
Hi, I've had several windsheilds replaced over the years and one time, they had the same problem. They took a 1500 watt hair dryer type of heat gun and went along the edges of the glass. This method really worked so you might consider trying it. Good Luck..
Steve in Saratoga Springs, NY
Old Jan 2, 2010 | 05:40 PM
91C2's Avatar
It also seems like the antennae is on the windshield does anybody know where the connection is?
Rob Shapland-Hill
Apr 22, 2012 10:03 AM
doctork
Apr 24, 2007 09:28 AM
ZinFaren
Mar 20, 2007 10:04 AM
Richard B.W.
Mar 12, 2006 10:52 PM
speedster89
May 16, 2005 09:35 PM
