911- STALLING WHEN STARTING
Old Aug 5, 2007 | 10:40 PM
85911carrera's Avatar
Default 911- STALLING WHEN STARTING
I have an 85 911 CARRERA which is well maintained and has app. 40,000 miles on it. I currently have a problem which I have not been able to correct which is dangerous as well as very aggravating.
The problem is that the car frequently starts to stall when starting in 1st and I usually can't do anything about it. This happening very early in acceleration and is very noticeable (the car bucks when it hits the flat spot during lower end acceleration (around 2000 RPM's). It is almost like the engine is stopping / missing for a split second and then either starting again or stoping. The idle is seems o.k except that its consistantly at app. 1000 rpm.s.
I believe this problem started after my faulty computer was replaced. Since then a lot was done to correct the stalling and idle problem including changing engine gaskets and the air flow valve. Nothing has completly worked.
Any suggestions re this will be very much appreciated particularly since I will be taking a road trip in the next 5-6 days and I may have the only 911 thats more dangerous at a stoplight than at the track
Thanks,
John
Old Aug 6, 2007 | 07:36 AM
Default RE: 911- STALLING WHEN STARTING
Sounds like an AFM meter problem to me.
Old Aug 6, 2007 | 09:29 AM
Thanks for prompt response. Will look into AFM meter
John
84944s
Jan 16, 2009 09:05 PM
911rookie
Mar 31, 2008 04:13 PM
LostAngel
Jan 2, 2008 11:45 AM
bocksterman
Oct 7, 2007 12:31 AM
PorscheAug
Jul 16, 2007 02:31 PM
