911sc oil leak
I have a 78 911 sc with a 964 3.6 litre engine. Problem is it is leaking oil. I have changed the rear main oil seal but it still leaks. The car is making 400 hp. There seems to be a crack on the block. Should I weld the block or change the casing?
