993 handbrake warning light
Old Jan 25, 2006 | 07:10 PM
mani's Avatar
Default 993 handbrake warning light
HI
I have just bought a 993 C2 Tip.
Should a warning light come up on the dash when the handbrake is pulled up ?
I drove around the block with the handbrake up and there was no light on the dash is
this normal ?
Also when selecting a gear should you press the button on the top of the lever or is that only
for reverse?
Thanks
Mani
Old Jan 26, 2006 | 01:30 PM
CTiggerPigglet's Avatar
Default RE: 993 handbrake warning light
Hi Mani, first off, may I welcome you to the forum?
The warning light with the ! symbol should be lit once the handbrake is applied.
I'm not sure about the button on the gear stick, be I would have thought that it was only to select reverse gear.
Do you not have the drivers manual? It should tell you in there.
Lion Heart
Apr 6, 2009 12:55 AM
Zechs
Jan 5, 2008 08:10 PM
porschenein59
Oct 8, 2006 01:19 AM
spooey
Jul 19, 2006 04:43 PM
Darvious
Aug 10, 2005 03:20 PM
