-   -   O2 Oxygen Sensor (https://www.germanautoforums.com/forum/porsche-911-8/o2-oxygen-sensor-4542/)
goebels97 Oct 28, 2007 07:36 AM
O2 Oxygen Sensor
I have a 99 Porsche 996 that needs 2 oxygen sensors replaced. How much money am I looking at to repair. Also, besides the check engine light coming on, can I still drive it for a short time before having replaced or will this cause damage possibly. Thank you.
ladams1 Oct 28, 2007 04:18 PM
RE: O2 Oxygen Sensor
I had the same problem on my 1999 996. It cost about $1200. Ouch! One of the reasons I felt it was time to buy a new Porsche.
Good luck
Lee
PorscheDoc Oct 28, 2007 07:16 PM
Sensors are about $200 each, and about an hour to replace them.
ladams1 Oct 29, 2007 08:46 AM
ORIGINAL: PorscheDoc
Damn did I get screwed :(
Doc the dealer told me their were 4 sensors and I had 2 bad. Any chance I had a different sensor that is more expensive? When I took the 1999 911 in for annual service they told me the sensors where showing failure with their plug in CPU. They said they were surprised I did not have an "engine service" light yet.
Sure enough 3-4 weeks later the light came on.
Comments.
Thnaks Lee
PorscheDoc Oct 29, 2007 10:09 AM
Yes there are 4 sensors total, 2 on each side. If one goes bad, you always replace that one, with the other one on the same side. They are just bosch sensors (no differences), which the dealer marks up probably 200% over retail.
goebels97 Oct 29, 2007 10:37 PM
What tools will I need to replace . I have the diagram to follow. Size etc to remove the sensor. My codes are P1123 and P1125. Are these part 993-606-118-01 or 993-606-128-01 for my 99 porsche 996, post or pre catalitic ? Thank you. -Kip
PorscheDoc Oct 30, 2007 08:23 AM
You need a 22mm wrench for the sensors. Those are the sensors. The 993 part number is the post cat sensor. I would imagine the standard wrench size would be a 15/16 or a 7/8?
pwarner Oct 30, 2007 04:50 PM
Your problem may not be oxygen sensors - It may be the MAF (Mass Air Flow) sensor. My '99 996 also thru those OBDII codes, but replacing the MAF ($260-$300 mail order) fixed the problem. All you need is the right security torx bit (a torx bit with a hole in the bit end) to replace the sensor, and it takes all of about 5 minutes.
PorscheDoc Oct 30, 2007 06:36 PM
If the codes are from the same bank, then it is the oxygen sensors. If you have a sensor showing bad on each bank, then the MAF is bad.
goebels97 Oct 30, 2007 10:56 PM
Im sorry for the stupid question, but what do you mean by the same bank. I have learned soooo much information about my car reading posts and asking questions on this website. Thank you very much.!!!!
