RUF Announces their new eRUF Model A.
Old Oct 13, 2008 | 04:24 PM
Patrick's Avatar
Administrator
Default RUF Announces their new eRUF Model A.
RUF has become well known around the world for their ultra high performance Porsches, and with companies scrambling to release alternative powered vehicles, aftermarket companies are joining the battle. Rumors surfaced a few months back about RUF offering an electric high performance Porsche, and those rumors were centered on the popular Cayman. However, with this week’s announcement from RUF had some vague yet exciting details about the new eRUF Model A, which is based on the Porsche 911.
The new eRUF Model A, which is still completely in its conceptual stages, has done away with the six cylinder gas engine in favor of a three-phase electric motor, which makes just 200 horsepower, but the 450 lb-ft of torque available throughout the entire powerband allows the eRUF to dash to 60 in under 7 seconds. This system utilizes a similar setup to that used on the hydroelectric power plants owned by Alois Ruf, which make over 35 million kilowatt hours to the German public per year. That amount of energy is enough to send the eRUF around the world 3500 times, so a smaller scale system has been used in the Model A.
Here are the published specs from RUF:
Drive Performance
• Acceleration 0-60 mph under 7.0 sec (development target)
• Vmax 160 mph, 225 km/h
• Cw 0.28
• Roll resistance 0.014
• Driving range approximately 250 – 320 km, depending on
performance level
• Specific power pick-up 21 kW / 125 km/h
Vehicle data
• Engine power 150 kW / 204 PS
• Max torque 650 Nm 7 0 rpm
• Weight 1910 kg (preliminary data)
• Battery weight 550 kg
Motor Data
• Max torque + 650 Nm to -650 Nm
• Power + 150 kW to -150 kW (peak level)
+ 204 hp to -204 hp
100 kW / 136 hp continuous
• Currency 300 – 420 Volt
• Current level max 550 A
• Rpm level max 5000 rpm
• Operating system brushless three phase alternating current with
permanent magnets
Dimensions
• Diameter 405 mm
• Length 241 mm
• Weight 91 kg
• Specific weight 1,65 kW / kg, 2,25 hp / kg
• Coolant flow 8 L /min max
Battery System
• Type Lithium-Ion, iron-phosphate base
• Manufacturer Axeon plc, GB
• Stored Energy (96 units) 50,72 kWh
• Nominal Voltage 317 Volt
• Maximum discharge 480 A
• Max Power 152,16 kW = 210 PS
• Charging current, max. 16 A
• Charging time 10 hours
Single Battery Cell Data
• Capacity 160 Ah
• Operating voltage 4,25 V charging, 2,5 Volt discharging
• Nominal Voltage 3,3 Volt
• Max. Temperature Level 80 °C
• Life cycle 3000 charging cycles
• Self-discharge under 3 % per month
• Weight per Unit 5,6 kg
There hasn’t been much information released by RUF, but we can expect to know more exact specifications about the eRUF Model A in the coming months.
Old Jan 21, 2011 | 12:16 PM
samiparker's Avatar
wow, thats an amazing combination infact, I really like the way they are making the new models.
Old Feb 10, 2011 | 11:24 AM
porscheTechnik's Avatar
Thanks for the great information. I am currently in the market for an older 911 TT. Any suggestions on how to find a
qualified inspector for a car that I might be looking at in another state? What about if I am looking at purchasing a car
from a Porsche dealer? Any specific issues to be concerned about with the 911 TT?
Thanks!
http://www.porschetechnik.com/
Old Feb 18, 2011 | 03:12 PM
hart123's Avatar
The models developed are really awesome and dam good. i just liked it to the core. thanks for letting us know.
Cheap Porsche Online Store
Old Apr 21, 2011 | 02:19 PM
Abbas's Avatar
Most cars come with some tax on, if this is the case, then you have no worries as the tax goes with the car, not the person. so it will not need taxing again until it runs out. if it is new it will have a years tax arranged by your dealer.
Old Jun 26, 2011 | 03:51 PM
Roobin Holmes's Avatar
Boat building has been one of the earliest forms of engineering and hobby as well. Most hobbyists prefer to build themselves a boat rather than buy. Why? Above all other reasons, it is simply because they take glory in calling their craft their own. What about you? Why build your own boat?
Old Aug 21, 2011 | 07:54 AM
Olivia001's Avatar
Old Oct 11, 2011 | 09:54 PM
johnsmith's Avatar
Really you've provided a great information here and the models are also very gud. I like your views and hope from you to continue this discussion in near future also.
Old Dec 1, 2011 | 03:30 AM
divakar's Avatar
Default regards
seeing the driving performance tag, i was shocked and stayed like an statue for few seconds. well that will help me out lot, thanks for posting. please keep updating.
Old Dec 1, 2011 | 03:51 AM
  #10
divakar's Avatar
Default regards
