1980 924 Turbo (931) - Interference engine??
Old Sep 5, 2007 | 08:33 AM
Shogun1011's Avatar
Default 1980 924 Turbo (931) - Interference engine??
Hey all,
I've got a chance to aquire a 1980 924 Turbo that has been sitting for many years. 55K miles, i believe the timing belt was changed prior to it sitting...but that was 15 years ago when it was finally parked. So, i'm going to change the timing belt before i even try to turn it over. I was wondering... is the 924 Turbo an interference engine? Also, does it have an auto tensioner?
Thanks!
Shamus
Old Sep 5, 2007 | 08:56 AM
Default RE: 1980 924 Turbo (931) - Interference engine??
I know the 2.0 NA engine was a non interference engine, but for some reason it is sticking in my mind that the 931 was indeed an interference engine. I can do some research and let you know for sure.
Old Sep 5, 2007 | 09:32 AM
Shogun1011's Avatar
Thanks so much!! I tried to find info through google..but have had no success.
Old Sep 5, 2007 | 09:39 AM
Yes, the turbo is an interference engine.
Old Sep 5, 2007 | 09:49 AM
Shogun1011's Avatar
Does it have an automatic tensioner like other 924's..or is it similar to the 944 (regarding steps to change the timing belt)
thanks,
Shamus
Old Sep 5, 2007 | 06:16 PM
D Hook's Avatar
Sorry, no auto tensioner. But it's an easy one to do, unlike the 924S / 944 engines.
Old Sep 5, 2007 | 08:23 PM
Shogun1011's Avatar
got any tips for me? I've done timing chain replacements on old 86 toyota turbo pickups...and there's always some hidden bolt, or some trick to make it easier.Hopefully it's not as involved...
With a 22r/re/rte engine:2
remove radiator + hoses
removepully belts
remove distributor cap
remove valve cover
Find TDC, mark distributor, pop crank bolt of by bumping starter with breaker bar against frame
Find TDC again (lol)
Remove powersteering pump
Remove water pump
Remove hamonic balancer
Remove oil pump
remove oil pan front bolts
remove distributor
remove hidden bolt underneath oil
remove timing cover
remove cam gear
(and that's just to get to the timing chain)....
~Shogun
Old Sep 5, 2007 | 09:19 PM
D Hook's Avatar
It's pretty straight forward.
Remove the belt cover.
Loosen the tensioner wheel.
Remove old and put on the new belt.
Tension until you can only twist the belt 90°.
If it whines after tensioning, you have it too tight. Back it off slightly.
New belts are cheap. Valves are VERY expensive!
Old Sep 6, 2007 | 07:12 AM
Shogun1011's Avatar
wow...that IS really easy! smart design!
thanks,
Shamus
Old Nov 17, 2007 | 03:15 AM
  #10
ugly77's Avatar
anybody got a link on how to do it? i just got my 924 NA 2.0L and am getting the maintenance up to date. what i really need is pics of the timing marks and info on where they are.
Brian Naughton
Oct 15, 2014 06:23 PM
931owner
Jan 13, 2009 12:10 AM
joff931
Nov 7, 2007 05:48 PM
Shogun1011
Sep 8, 2007 05:03 PM
Shogun1011
Sep 7, 2007 07:55 PM
