1980 924 Turbo (931) - Interference engine??
Hey all,
I've got a chance to aquire a 1980 924 Turbo that has been sitting for many years. 55K miles, i believe the timing belt was changed prior to it sitting...but that was 15 years ago when it was finally parked. So, i'm going to change the timing belt before i even try to turn it over. I was wondering... is the 924 Turbo an interference engine? Also, does it have an auto tensioner? Thanks! Shamus |
RE: 1980 924 Turbo (931) - Interference engine??
I know the 2.0 NA engine was a non interference engine, but for some reason it is sticking in my mind that the 931 was indeed an interference engine. I can do some research and let you know for sure.
Thanks so much!! I tried to find info through google..but have had no success.
Yes, the turbo is an interference engine.
Does it have an automatic tensioner like other 924's..or is it similar to the 944 (regarding steps to change the timing belt)
thanks, Shamus |
Sorry, no auto tensioner. But it's an easy one to do, unlike the 924S / 944 engines.
got any tips for me? I've done timing chain replacements on old 86 toyota turbo pickups...and there's always some hidden bolt, or some trick to make it easier.Hopefully it's not as involved...
With a 22r/re/rte engine:2 remove radiator + hoses removepully belts remove distributor cap remove valve cover Find TDC, mark distributor, pop crank bolt of by bumping starter with breaker bar against frame Find TDC again (lol) Remove powersteering pump Remove water pump Remove hamonic balancer Remove oil pump remove oil pan front bolts remove distributor remove hidden bolt underneath oil remove timing cover remove cam gear (and that's just to get to the timing chain).... ~Shogun |
It's pretty straight forward.
Remove the belt cover. Loosen the tensioner wheel. Remove old and put on the new belt. Tension until you can only twist the belt 90°. If it whines after tensioning, you have it too tight. Back it off slightly. New belts are cheap. Valves are VERY expensive! |
wow...that IS really easy! smart design!
thanks, Shamus |
anybody got a link on how to do it? i just got my 924 NA 2.0L and am getting the maintenance up to date. what i really need is pics of the timing marks and info on where they are.
| All times are GMT -5. The time now is 02:00 AM. |
