-   Porsche 928 (https://www.germanautoforums.com/forum/porsche-928-37/)
-   -   Starting Problem....HELP ASAP!!! (https://www.germanautoforums.com/forum/porsche-928-37/starting-problem-help-asap-4700/)
rocks_n_stones21 Nov 21, 2007 08:19 AM
I recently purchased a 1986 928S, and drove it around beautifully for about 500 miles, then all of a sudden it wont start.... it cranks and cranks but never starts. I can hear the fuel pump relay click on and off... but can not hear the pump whine... ive checked the fuses and everything seems good.
I think it is a fuel pump that has gone out, and i have done research and found out that apparently i have 2 fuel pumps, one inside the tank and one outside... i can find the external one for purchase... but the internal one i cannot find.
Also, i cannot locate the pump either...can someone please help me locate it so i can replace it?
PorscheDoc Nov 21, 2007 09:49 AM
RE: Starting Problem....HELP ASAP!!!
You have two external fuel pumps. One is behind an accesspanel on the rear/bottom of the tank, the other is in the passenger rear wheel well in front of the tire behind the fender liner.
rocks_n_stones21 Nov 21, 2007 01:30 PM
2???? why 2?????..... if i replace the one in the bottom or the tank should it work? or do i have to replace both? again no sound comming from anything resembling a fuel pump sound!
PorscheDoc Nov 24, 2007 10:50 PM
Typically both pumps wont die at the same time, so I would check your fuel pump relay first.
To answer the question though, yes you need both fuel pumps working for the car to run.
rocks_n_stones21 Nov 26, 2007 02:12 PM
I think i only have one... i found the one in the back under the fuel tank. but not the one in the wheel well... orielies and autozone say that there is only one fuel pump. but i ordered the one from orielies and it was the wrong one... so i ordered one that had a picture identical to the one on my car from autoparts warehouse... we will see if that fixes the problem.
