1984 944 Radio problem
I got a 944 and there was no radio in it and the dumb ass that had the radio before me cut the plug off so i have no Idea which wire is the wire to Turn the radio on when you turn the key Ive tested all the wires and no fuses are blown none of the wires turn on and off with the Key what should I do?
RE: 1984 944 Radio problem
What year is the 944. I can tell you exactly what wires should be what if I know the year.
Well its actual the early 1985 944
Ok, give me a few minutes to pull some skematics.
Ok, my early wiring diagrams are a little sketchy, but it appears power from ignition should be a red wire with blue stripe. Constant 12v should be a red wire. Brown wires are speakers. White is for the antenna. Brown with red stripe should go to the balance switch.
awesome thanks I'll give that a try
