1984 944 Radio problem
Old May 15, 2006 | 06:38 PM
gyver_101's Avatar
Default 1984 944 Radio problem
I got a 944 and there was no radio in it and the dumb *** that had the radio before me cut the plug off so i have no Idea which wire is the wire to Turn the radio on when you turn the key Ive tested all the wires and no fuses are blown none of the wires turn on and off with the Key what should I do?
Old May 15, 2006 | 11:24 PM
Default RE: 1984 944 Radio problem
What year is the 944. I can tell you exactly what wires should be what if I know the year.
Old May 15, 2006 | 11:30 PM
gyver_101's Avatar
Well its actual the early 1985 944
Old May 15, 2006 | 11:37 PM
Ok, give me a few minutes to pull some skematics.
Old May 15, 2006 | 11:45 PM
Ok, my early wiring diagrams are a little sketchy, but it appears power from ignition should be a red wire with blue stripe. Constant 12v should be a red wire. Brown wires are speakers. White is for the antenna. Brown with red stripe should go to the balance switch.
Old May 15, 2006 | 11:47 PM
gyver_101's Avatar
awesome thanks I'll give that a try
daniel_moraes
Apr 26, 2008 07:11 AM
DEFTONES
Nov 30, 2007 12:07 PM
snappy
Aug 23, 2007 11:37 AM
wrinehart
Jun 15, 2007 02:49 PM
mutiny514
Jan 23, 2005 11:12 PM
