944 Drive shaft replacement?
Old Oct 8, 2007 | 12:42 PM
rich201283's Avatar
Default 944 Drive shaft replacement?
Hi my drive shafts appear knackered, Should there be any slop from side to side if i take hold of one and pull it towards the wheel, I have a loud tapping noise from the rear left side when cornering left at lower speeds. How easy is it to remove the drive shaft? Do you have to remove the gearbox?
Old Oct 8, 2007 | 09:55 PM
Default RE: 944 Drive shaft replacement?
Remove the bolts on each side, and drop the shaft out. No need to remove the transaxle. You might also want to inspect the wheel bearings on that side to make sure they are in good shape.
usc4jon
Feb 10, 2008 11:27 PM
usc4jon
Dec 10, 2007 08:53 PM
bgossett101
Feb 28, 2006 12:47 AM
kinderrich
Dec 30, 2005 10:37 PM
CTiggerPigglet
Oct 31, 2005 12:37 PM
