944 injector problem
Old Jan 3, 2006 | 05:26 PM
jaggraveyardcom's Avatar
Default 944 injector problem
1985 944 with new ref sensors. we have good spark and fuel to the fuel rail, but no injector pulse tried 2 brain boxes...tach does not jump on cranking any ideas? we are jag guys and dont know enough about this little jag treat
Old Jan 3, 2006 | 07:48 PM
Default RE: 944 injector problem
Replace the DME relay first. If the tach still doesn't bounce, then try setting the depth again of the reference sensor....it should be .8mm off the flywheel. If it still doesn't bounce, then i would bet money that you have a bad wiring harness. Cut the wires open on at the connection to the reference sensor (on the wiring harness side) I would bet you have some broken wires.
obboardcamera
Jan 24, 2007 04:49 AM
Bob259
Jul 29, 2006 01:53 PM
SHARKY
Jun 22, 2006 04:23 PM
foz
Mar 11, 2005 07:18 PM
kit1111
Jul 11, 2004 12:38 PM
