cylinder head
im planning an engine rebuild for my 944 later in the year, and toying with the idea of a turbo. what i want to know is as follows. is a cylinder head from a turbo interchangable with a n/a engine?
thauts, suggestions, ideas? thanks -kevin |
RE: cylinder head
The turbo head has a ceramic coating on the exhaust ports to handle the added heat, but will bolt right on to your na. Then all you have to worry about is the transmission, clutch, breaks and front suspension. There are reasons a turbo is a turbo and an n/a isnt. The best hing you could do would be sell the n/a and buy a turbo. (just my opinon) Or rebuild the n/a as an n/a.
RE: cylinder head
[:o]hello i have a 1984 944 and i just had to put a new head gasket on. but i dont know the toque spec on the valve cover can any one help me?
RE: cylinder head
ORIGINAL: scot [:o]hello i have a 1984 944 and i just had to put a new head gasket on. but i dont know the toque spec on the valve cover can any one help me? |
