cylinder head
Old May 11, 2007 | 09:27 PM
riker's Avatar
Default cylinder head
im planning an engine rebuild for my 944 later in the year, and toying with the idea of a turbo. what i want to know is as follows. is a cylinder head from a turbo interchangable with a n/a engine?
thauts, suggestions, ideas? thanks
-kevin
Old May 12, 2007 | 06:50 PM
kinderrich's Avatar
Default RE: cylinder head
The turbo head has a ceramic coating on the exhaust ports to handle the added heat, but will bolt right on to your na. Then all you have to worry about is the transmission, clutch, breaks and front suspension. There are reasons a turbo is a turbo and an n/a isnt. The best hing you could do would be sell the n/a and buy a turbo. (just my opinon) Or rebuild the n/a as an n/a.
Old Jun 26, 2007 | 07:17 PM
scot's Avatar
[]hello i have a 1984 944 and i just had to put a new head gasket on. but i dont know the toque spec on the valve cover can any one help me?
Old Jun 26, 2007 | 07:35 PM
ORIGINAL: scot
Cam tower bolts are torque to 15ft/lbs.
GaryLeeman
Jun 4, 2009 09:07 AM
MikeV
Jan 7, 2008 07:45 AM
RATNIK
May 20, 2007 02:18 PM
Sheng
Mar 10, 2007 09:37 PM
944 nutz
Mar 26, 2006 12:53 PM
