Different gear ratios???
I am combining two 944's and wanted to know if I have different gear ratios in the two transaxles. With the canyon passes around here I would prefer a numercially higher ratio. Here are the two VIN's, or do I need something else?
WP0AA0945GN455480 - GOLD WP0AA0948FN457772 - RED |
RE: Different gear ratios???
How about with the numbers on top of the bellhousings????
Red- 5S03055 Gold-5S30115 |
what year and model are the 944's?
1985.5 944 N/A
1986 944 N/A I got a hold of 944online.com tech and he said all of the 5S (ist two #'s on bellhousing) are 9:38 gears and open diff. I got the bad motor pulled out last night, through the top no-less!!! I thought it could be done. Although the intake was already off, I still needed to pull the power steering pump and steering shaft... |
Got the new motor in (from the top) and almost everything underneath back in. Now comes the fun of changing the wiring harness and all the vacum lines....
