electric fan draining battery
Old Mar 4, 2008 | 07:27 PM
whiplash_s's Avatar
Default electric fan draining battery
my electric fan stays on after car has been driven and drains the battery everytime, I unhooked the fan for now but car runs alot hotter. any suggestions on what to replace and where it is located at? thanks.
Old Mar 4, 2008 | 07:39 PM
Joe85.5's Avatar
Default RE: electric fan draining battery
If I'm correct there's a thermo fan switch on the upper left side of the drivers cooling fan. That would be a place to start.
Old Mar 4, 2008 | 09:53 PM
petera951's Avatar
hi, my '88 turbo had exactly the same problem. in my case, it was the fan relay, which is in the fuse box. you can unplug it to stop the fan (the diagram on the fuse box cover will tell you which one) but you'll need to replace it for it to run properly, an easy fix. hope that helps.
Sam Shalala at Protechnik in Houston diagnosed it in 30 sec and plugged in a new one, all is well.
Old Mar 5, 2008 | 08:31 AM
Replace your fan switch first on the radiator, as that is about 20 bucks. The fan relay is pretty expensive IIRC, but can definitely cause those symptoms as well.
Skywalker
Sep 22, 2008 10:13 PM
100dollarcar
Jul 3, 2007 05:06 PM
rdulala
Jun 14, 2007 12:56 PM
texasferret
Jun 3, 2007 09:16 AM
buddyjarvie
Dec 23, 2004 11:49 AM
