engine lower end oil leaks
Any idea what, shop time, is involve with replacing the lower end oil seals? I noticed, after pulling the bottom plastic pan, that most of the oil leak is coming from the lower front end.
RE: engine lower end oil leaks
Front engine seals are about 13 hours.
It is not to bad of a job... I would recomend that you try to locate all the leaks , and replace everything that is involved in one job. It is much easiler to get to things like the oil cooler ,while you have it tore down. Neal
