engine lower end oil leaks
Old Dec 19, 2006 | 08:52 PM
mytrplseven's Avatar
Default engine lower end oil leaks
Any idea what, shop time, is involve with replacing the lower end oil seals? I noticed, after pulling the bottom plastic pan, that most of the oil leak is coming from the lower front end.
Old Dec 19, 2006 | 09:36 PM
Default RE: engine lower end oil leaks
Front engine seals are about 13 hours.
Old Dec 20, 2006 | 06:18 PM
88_944's Avatar
It is not to bad of a job... I would recomend that you try to locate all the leaks , and replace everything that is involved in one job. It is much easiler to get to things like the oil cooler ,while you have it tore down. Neal
jefm
Feb 8, 2011 07:32 AM
DMSD
Jul 20, 2006 02:04 AM
DMSD
Jul 20, 2006 02:03 AM
Zechs
Nov 30, 2005 10:58 AM
Turboguy930
Nov 29, 2005 02:43 PM
