engine rebuild
Hi there i have recentyl just picked up a 1986 944. I am new to the porsche world so i hope you guys can help me out a bit. I am looking to see how much an engine rebuild kit would cost me. The motor has 215000 on the odometer so i think it is time for a rebuild. It also leaks oil. Any kind of input is greatly appreciated!
Plan on about $2500-3000 for all the parts you will need to rebuild an engine.
Things you will need:
Rod bearings
Main bearings
Piston rings
Valve seals and guides
Crankcase gasket set
Head gasket set
Waterpump
Timing belt, balance shaft belt, alternator, and power steering belts
All rollers for T&B belts
Front engine seal kit
Camshaft bolt
Loctite 574 (50ml minimum)
Various coolant hoses depending on what needs to be replaced.
Rod bearings
Main bearings
Piston rings
Head gasket set
Waterpump
Camshaft bolt
