Exhuast Headers
Old Jan 4, 2007 | 07:09 PM
AbsolutCarCrazy's Avatar
Default Exhuast Headers
During my last post, i had a problem, and i found it. The dreaded manifold crack. whoopity doo. NOW, ive done some searching and the only aftermarket/performance headers i can find are the B&B stock replacement, are there any other performance enhancingavailable? And when i completely remove the old headers, is it easier to cut/remove the old studs from the head and install new ones? or lift the engine an inch or so? If i lift the engine will i have to unhook anything else besides the motor mount? Thanks for any help
Old Jan 4, 2007 | 07:33 PM
Default RE: Exhuast Headers
Do not cut the studs. You need to double nut the studs and remove them completely, then you can remove the headers.
Deaner
May 22, 2008 02:00 PM
OnesickCarreraGT
Apr 14, 2008 01:04 AM
wydryd
Jan 25, 2008 08:13 PM
nitwit
Dec 18, 2006 05:05 PM
engineer
Apr 13, 2006 11:15 AM
