A few noob questions...
Just purchased a 1986 944 Turbo.
1 - It has not been started in 2 years. Is there anything I should do prior to turning her over? Anything need to be primed? Should I pull the plugs and put a squirt of oil in there? Anything special need to be done with the turbo since it has been sitting for so long?
2 - The clutch stays on the floor. Is it the clutch master cylinder or the slave cylinder? How difficult is the install of each? No stranger to wrenching... I'm a Land Rover owner!
Thanks for your patience!
ORIGINAL: stevenmd
bump... don't want to do any damage. Anyone have suggestions prior to firing her up?
