Front suspension rebuild
Hi
I'm planning to redo and upgrade the entire suspension system for autocross, but also for street use. I can't afford to buy everything at once so I'm doing it one step at a time. So far I have Bilstein HD shocks for the rear. My next step is to replace the shocks and springs in the front. I was wondering if somebody could help suggest what to go with in the front. I was considering either getting matching Bilsteins or getting the adjustable Koni sports and matching it with a pair of 220lb Weltmeister springs. Any advice on this setup. The next step would be to get stiffer sway bars, and finally replace the torsion bars. As for replacing the front, I know I need a spring compressor, I can buy or rent that, but there is some issue with needing an air ratchet or a special tool to loosen a bolt. Is there any advice on the best way to handle that as well. Thanks alot...
[align=left] [/align]
If you upgrade your torsion bars later, you will also need to go with heavier front springs, so keep that in mind. Going with say, a 28mm torsion bar will require at least a 350lb front spring.
With some very slight modifications, you can take early 83 strut housings, which have removable inserts, toss the inserts, and install bilstein inserts, and you will have a great suspension setup.
You will want to use an air ratchet to screw on and off the top nut on the struts, you can do it with an allen and a wrench, but it will take you awhile, as well as doing it with the spring compressors installed is a bit nerve racking. I'd take it to a shop and have them buzz the springs on and off for you.
feke321
Apr 2, 2010 09:17 AM
johnny hatchback
Dec 4, 2007 12:14 PM
ZONDERVANUS
Jan 12, 2007 10:26 PM
ZONDERVANUS
Jan 11, 2007 02:50 PM
ZONDERVANUS
Jan 11, 2007 02:38 PM
