fuel pump need help
Old Oct 18, 2005 | 10:48 AM
scline's Avatar
Default fuel pump need help
I ordered a new fuel pump for my 87 turbo and it is about 1/2 the diameter of the one I am replacing. I am sure it is the right part number but not sure if it is the right part - has anyone else ever changed their pump and if so did you have the same experience? I am not sure if I should put it on or not - the local dealer was no help.....
I have already replaced the filter and the fuel pressure regulator hoping the pump is the reason it won't start.
Old Oct 18, 2005 | 01:06 PM
Default RE: fuel pump need help
Stupid question, but did you replace the dme relay before questioning the pump working or not? Every pump i have replaced has been the same, but maybe the incorrect pump was in there to start with....or an aftermarket pump.
Old Oct 18, 2005 | 02:27 PM
scline's Avatar
yes I did replace the DME, forgot to mention it. thanks
Burt0ng1rl
Nov 29, 2008 09:53 AM
deron888
Jun 5, 2007 02:04 AM
SPEEDRACER400
Jan 30, 2006 11:08 AM
xtraxstar
Mar 22, 2005 11:43 AM
mmkramer
Oct 1, 2003 07:30 PM
