Help !! 1983 944 gets no power at fuel pump fuse
Old Jun 5, 2007 | 02:04 AM
deron888's Avatar
Default Help !! 1983 944 gets no power at fuel pump fuse
Hello, my first post here and hopefully you experts out there can help
I do not get any power to fuse #2 for my fuel pump.
1. I have replaced the fuel pump relay and it seems to click when i turn on the ignition. Does not help. Should I manually test the unit with my multi-meter?
2. I looked under around the main fuse panel (the one with the relays on it) and found a loose black/red stripe wire. I am not sure which connector this wires goes to. Is this related to my problem?
Thanks for all the help you can provide !!! Right now I am not getting any juice to my fuel pump...
Burt0ng1rl
Nov 29, 2008 09:53 AM
ppwcanada
Sep 10, 2007 10:30 PM
PorschePilot
Jun 16, 2007 11:24 AM
scline
Oct 18, 2005 02:27 PM
xtraxstar
Mar 22, 2005 11:43 AM
