heater control valve
Old May 31, 2008 | 05:27 PM
spiney norman's Avatar
Default heater control valve
I was replacing the heater hose that goes from the heater control valveto theheater core and I knocked of a couple of vacuum lines loose next to where the hose connects to the heater core. One is coming from the heater control valve and the other I think is coming from the brakes. Does anyone know which line goes on the top. The heater control valve or the breakline?
Thanks
Old Jun 1, 2008 | 02:08 PM
Big Bob's Avatar
Default RE: heater control valve
I cannot give you an answer, but with the Engine running have both lines got a vacuum effect?Ie do they both have a suction on them. Normally the Heater Valve only gets vacuuum when you Switch the Heater Off, as the Vaccuum closes the Valve, to stop hot water going to the Heater Core. This may help you to figure out which is which.
Hopefully [8D]
Big Bob
High Definition
Mar 30, 2012 07:55 PM
Easy944
Feb 10, 2007 05:47 AM
99silver911
Sep 3, 2006 01:11 AM
bajabubba40
Jul 15, 2005 03:52 PM
