HELP AGAIN!
Old Aug 31, 2007 | 11:30 AM
AJones007's Avatar
Default HELP AGAIN!
Alright Well Were At The Track (The Car Is) And It Still Is Dying When We Lean Off The Throttle. Replaced The DME Relay + New MSD Coil. And Still It's Pulling This Spuddering After A Good Lap Session. Like I Said It's Not A Problem During WOT It's After A Good Beating On The Track, And It's Popping Meaning I Know There Is Fuel, It's The Detionation That Seems To Be An Issue, One Guy Is COnvinced It's A Ground Issue. Would Love The Input, Any Ideas Or Things To Look For. This Is Only Day One Of Four!
A. Jones
Old Aug 31, 2007 | 01:59 PM
Default RE: HELP AGAIN!
Well, if you are having detonation, then you sure as heck don't have enough fuel! Check your fuel pressure regulator.
Old Aug 31, 2007 | 02:18 PM
AJones007's Avatar
What Am I Checkin' For.. I Am At The Track??????
Old Aug 31, 2007 | 03:52 PM
You need to start by checking your fuel pressure. Normal reading at idle is about 2 bar, 1 bar after 20 minute leakdown, and 2.5 bar with the fuel pump relay jumpered on the 8V engines.
Turboguy930
Dec 22, 2005 05:44 PM
TheDarkPlatypus
Nov 5, 2005 07:02 PM
Trader4Less
Apr 15, 2005 06:59 PM
Trader4Less
IaMtHeRuThLeSs1
Oct 22, 2004 04:24 PM
