Intermittent Power window operation
Hello. I'm new here and looking at a '86 944 to purchase. I have found one that is in great mechanical and cosmetic shape, but it has a problem with the power windows. Basically, they work 90% of the time and once in a while don't. Is this very common? Perhaps an easy fix?
Any help on this would be great. |
RE: Intermittent Power window operation
same thing happens to me, but only on the passenger side window, but if i lean over and toggle the passenger side switch it will all of a sudden work on my side control, i dont know too much about it just take it off and check the connections. I dont really care considering its been hot out lately and cant turn my heat off
haha Cheers, Dave |
Could be a loose ground or your power window relay.If it works 90% of the time it may be hard to track down. Try tapping on the relay nex time it happens.
[IMG]local://upfiles/1568/8FE7C1C2D6E24F75A185343A84B68621.jpg[/IMG] |
More than likely bad switches.
