Oil Gauge question
Old May 21, 2007 | 08:13 PM
q5ka's Avatar
Default Oil Gauge question
I have been looking over the threads. I have one difference to most. I have just replaced the oil pressure sender. As soon as I turn on the key the gauge jumps to peg 5. The Idiot light comes on and as soon as I start the car the Idiot light goes away but the gauge is still 5+. The old unit would have the gauge either peg 5+ or 0 or even sometimes kinda work. The Idiot light would flash when idle after engine good and hot. Hence why I would like the gauge to work. The old sender looks like the original 85.5 unit. I don't trust the idiot light but no working gauge. Could it be possible I got a new broken sender? Could the wire be possibly bad? How can I check the wire? I find it weird that the gauge is 5+ as soon as the key is turned on. Any help would be greatly appreciated with this.
Old May 21, 2007 | 09:43 PM
Default RE: Oil Gauge question
It should not peg to 5 with just ignition, try swapping the wires around.
Old May 22, 2007 | 05:23 PM
q5ka's Avatar
I checked the wires again and also placed an ohm meter on the sender. The sender is showing variations with rpm so it has to be either the wire or the gauge. I have an odometer gear coming hopefully this week so I will check the gauge and wire to the gauge when I replace the gear. Thank you for all your help and any hints would be helpful.
Pol-can
Nov 27, 2012 04:51 PM
pedalmasher
Dec 29, 2008 10:21 PM
johnsonsa
Oct 14, 2007 10:54 AM
78mk1dubber
Jul 8, 2007 11:13 PM
BIBBER
Jun 13, 2006 10:38 PM
