oil leak
Old Mar 2, 2009 | 09:04 PM
jfries89's Avatar
Default oil leak
what are some common oil leak spots on the front passenger side of the engine?it drips down onto this bar and the steering boot
[IMG]local://upfiles/8001/7A7AED899CF94E0A8B464A132FA4C6CF.jpg[/IMG]
Old Mar 2, 2009 | 11:22 PM
Default RE: oil leak
power steering leaks, and any of the front engine seals.
Old Mar 3, 2009 | 06:59 AM
jfries89's Avatar
how hard is it to remove the timing belt cover?
Old Mar 3, 2009 | 02:07 PM
Front engine seals is about an 11 hour job. You will have to remove the timing and balance shaft belt, and if the waterpump hasn't been done recently, you might as well do that while you are in there.
Old Mar 3, 2009 | 03:27 PM
jfries89's Avatar
where can i get the seals? i figure since i have it all apart i might as well do all those seals and belts and i can get the belts from autozone but they dont have the seals
Old Mar 3, 2009 | 06:38 PM
I don't know that I would trust a timing belt or balance shaft belt from autozone. Not something you want to cheap out on. I would get it all online at vendors such as paragon-products.com Talk to Chuck or Jason, they will know exactly what you need to do the job.
Old Mar 3, 2009 | 07:34 PM
jfries89's Avatar
wow! thats a great site! thanks! also, do you kno of any good write ups on this?
Old Mar 3, 2009 | 09:28 PM
Maybe check out the garage shop manual at clarks-garage.
Jacob25119
Jun 3, 2009 03:50 PM
lgriffi
Jul 30, 2006 09:47 PM
jim5_0
Sep 12, 2005 02:02 AM
jac
Apr 5, 2005 11:36 PM
AKRoorda
Feb 4, 2005 12:26 AM
