Power Locks
I don't know if this is an issue with my 87 944. When I lock/unlock the passenger side with the key, the driver side locks/unlocks as well, but not true if I do the same from the driver side; only the driver side locks/unlocks. The lock/unlock console button only works with the driver side door, although I hear clunking noise from the passenger side door, but the lock plunger does not move. Any similar experiences?
RE: Power Locks
The actuator inside the passenger side door sounds like its bad. Both sides should unlock from either side when you use the key.
Regards, |
