rear hatch switch
Old May 17, 2005 | 09:43 PM
pppm491's Avatar
Default rear hatch switch
I don't have any idea how this system is to work,but i need help! I have a rer hatch that does not open with the switch. I would like to remove the switch to do some checks. HELP Paul
Old May 18, 2005 | 12:24 AM
Default RE: rear hatch switch
More than likely it is the motor that is mounted on the rear fender that is triggered by the switch. I imagine you can remove it (3 bolts IIRC), take it off, and apply power to it to test to see if the armature moves.
Old May 18, 2005 | 01:51 PM
sh944's Avatar
Are you hearing the motor but its not opening the hatch? Or is the motor not working? If you can get someone to hit the switch while you look at the assembly, you'll be able to tell whether its working or not without disassembling anything. If the motor isn't moving, start with the fuse. If it is, its most likely the cable adjustment or the hatch pins that need to be adjusted.
Regards,
Old May 20, 2005 | 12:06 AM
pppm491's Avatar
I have supplied power to the hatch motor and it does open the hatch. also the fuse is operational because the lighter works.I need to remove the switch to see if there is voltage to the switch, and/or connecting thru Paul
Old Jun 1, 2005 | 11:08 PM
bearone2's Avatar
all you'll hear is a click.
use the key to open/close the retention collars and lube with something to see if the collars are releasing. i use wd40.
try some electrical cleaner that isn't too abrasive or eats plactic on the switch.
KurtsCayenne
May 4, 2012 04:41 PM
trathjen
Aug 23, 2007 11:45 AM
trathjen
May 9, 2007 01:44 PM
Skywalker
Feb 4, 2007 12:13 PM
nitwit
Jul 12, 2006 04:47 PM
