Spark Plugs make a Difference?
Old Jan 3, 2010 | 11:11 AM
84944s's Avatar
Default Spark Plugs make a Difference?
Hi Folks,
Just had a general tune-up done on my '84. Decided to drop the car off for new wires/plugs, cap/rotor and oil change. Thought it would be a nice Christmas present for my little red sled. Well, it is actually running a little rougher at idle since the tune-up. Asked the mechanic what he thought of the poor performance after the tune-up he said "that it may be because I was using a plug that was too hot (Platinum V Groove) and that he changed the plugs back to the recommended plug. Does this sound right to you? The car was idling fine before. I just thought I'd replace the old ignition wires and plugs as they were getting old
Old Jan 3, 2010 | 12:51 PM
Sure, running a hotter plug could have masked a running issue with the car. How rough is rough? I assume he plugged the wires back in the correct order.
Old Jan 3, 2010 | 01:27 PM
84944s's Avatar
Hi Doc,
Yeah, he plugged the wires in right, my only minor concern is that the car lost 100rpms at idle, a little rougher than it was. Idle was suprisingly smooth before at 950ish, now I'm idling at 900-. No big deal, although I didn't realize that the switch to a different plug would cause a slight reduction in the prior smooth idle. If I was sure that the hotter plug wouldn't be a concern for premature engine failures, I think I'd prefer the performance of the Platinum V plug, at least in reference to the way my car was running before.
Old Jan 3, 2010 | 05:06 PM
Sounds like a simple idle adjustment to increase the RPMS' a 100 or so and you will be good to go.
HP=$$$
Oct 1, 2007 10:49 PM
goebels97
Jul 14, 2006 07:41 PM
pioneer
Mar 23, 2006 10:53 PM
ericurena
Feb 26, 2006 09:54 PM
