Starter Problems - 2
Old Dec 4, 2005 | 09:35 PM
Welderguy's Avatar
Default Starter Problems - 2
Hi again, I am still having a problem with my 84 944 not starting. But I have a question, does the 944 have a switch to let the car know that the car is in neutal or that the clutch is in? Because in neutral, the car makes the same click noise when trying to start it if I have the clutch in or out. Just a thought. Thanks!
Mitch
Old Dec 4, 2005 | 09:55 PM
Default RE: Starter Problems - 2
Nope, you should be able to start it without the clutch.
Old Dec 7, 2005 | 02:39 AM
AHJax's Avatar
I have the same issue with my 84. I turn the key over and a slight noise, but nothing. Usually after 10 minutes i can start it.
Old Dec 7, 2005 | 02:40 AM
AHJax's Avatar
I will let you know what I find when I research the schematics
Old Dec 7, 2005 | 12:55 PM
Welderguy's Avatar
Figured it out yesterday guys! The +ive clamp on the battery, it has a clamp that the cable is tightened to the post clamp. I took the 2 1/4" bolts out and removed the bridge type clamp and found that even though the cable looked fine from 1st look, that there was a fairly thick buildup of corrosion and rust. Cleaned everything and put it back together. Better than new!!!!! Thanks for everything guys!!!
Old Dec 7, 2005 | 01:00 PM
CTiggerPigglet's Avatar
ORIGINAL: Welderguy
Yep, I thought that it may be a problem with the wires! Glad to see you're back on the road!!!
foz
Jan 6, 2006 05:02 PM
porsche94489
Dec 14, 2005 07:24 AM
Welderguy
Dec 2, 2005 10:27 AM
CTiggerPigglet
Sep 1, 2005 01:08 PM
jkaicher
Jan 23, 2005 11:10 PM
