Boxster Coolant
Old Oct 31, 2007 | 09:04 PM
mfshannon's Avatar
Default Boxster Coolant
I need to flush to coolant on a 1997 Boxster. Are there any recommended system flush and coolants for this car or will the normal extended-life, aluminum friendly products work fine? Thanks.
Old Oct 31, 2007 | 09:13 PM
dedes's Avatar
Old Oct 31, 2007 | 10:42 PM
dedes's Avatar
Default RE: Boxster Coolant
Also, check 986 forum
Read throught this thread.
http://986forum.com/forums/showthrea...ge=3&pp=20
Old Nov 1, 2007 | 09:29 PM
mfshannon's Avatar
Thanks for the links. We will have glycol water flowing on Saturday morning ...
Old Nov 1, 2007 | 09:40 PM
dedes's Avatar
If you are replacing the coolant..................
There is a Porsche coolant only that you want to buy. I believe you will find out it takes alot of coolant and $ dollars per gallon.
Check on PPBB and ask for more details about flushing your coolant properly. Or do a search for more information.
click here:
[align=left] Porsche Pete's Boxster Board (PPBB)
The main event... communicate with fellow Boxster enthusiasts.
[/align]
Other places to ask or do a search is Renntech forum
http://www.renntech.org/forums/index.php
BTW, do you have the coolant cap, the flat kind inside of the cap? The older cap does not seal well.
http://www.iwantaporsche.net/BoxsterInfo.htm
http://986forum.com/forums/showthread.php?t=13081
brianeshen@msn.com
May 27, 2007 11:57 AM
rockstarr
Apr 26, 2007 03:19 PM
SleekCarrera
Jun 9, 2006 04:55 PM
alanp
Nov 21, 2005 10:26 AM
kevfran
Sep 11, 2005 09:47 AM
