Help 1999 boxster thinkn of buying/ questions??
Old Mar 22, 2011 | 05:29 PM
want2gofast's Avatar
Default Help 1999 boxster thinkn of buying/ questions??
Went to a used car dealer selling a 1999 boxster problems it has: radiator reservoir is cracked and leaking, oil appears needs to be changed and needs new battery...going again to test drive it once a new battery is placed in it, dealer says he is going to replace the leaking reservoir?? ANYONE have any suggestions or advice on the reservoir leak problem? Should I be aware of any other problems related to this leak problem before I buy it?? Also how can I check for oil leaks, (by looking under car only??) Also wat problems with the convertible top should I be aware of? dealer put the top down and I was wondering is the hard plastic pretty strong enough to handle being down for periods of time?? ANY other things I should focus on when I go look and drive the car in a week?? (new to porsche boxster) YOUR HELP IS APPRECIATED...
ExcessiveEgo
Apr 3, 2010 03:54 PM
Scott449
Sep 19, 2008 09:38 PM
bobbyd
Sep 17, 2008 08:04 AM
Lazerblade
Oct 20, 2006 12:57 PM
Raptor
Jul 12, 2006 08:04 PM
