Radio code
yes hello everyone out there; i have purchsed a 2001 porsche boxter. The car is excellent. I had to disconnect the battery to turn off a check engine light off. However in doing that i have enabled the security system on the radio headunit. The radio is asking for a four digit code. However i do not know the code. So how should i resolve the problem?
thank , chris |
RE: Radio code
Pull the radio unit. On the side you need the serial number. Call Porsche with the serial number, and they will give you the code. You will need 2 radio removal tools to do this. Any stereo shop can pop it out quick and write the number down for you.
