2009 cayenne turbo s, water in headlight assembly, faulty control unit
Old 07-28-2017, 03:15 PM
joko's Avatar
Default 2009 cayenne turbo s, water in headlight assembly, faulty control unit
This weekend I discovered water inside the driver side headlight assembly. I also received a system fault warning on the dash. Inspection of the headlight assembly revealed no cracks or defects, so how did the water enter? Now I am told I need to replace the control unit on both sides otherwise they will not work properly. Before I do this I would appreciate any input regarding similar experiences or suggestion on where the water may have entered. I do not want to make this expensive repair only to have the problem recur. Thanks
Old 02-16-2019, 01:27 PM
Pepperman's Avatar
I had that same problem! I put selicone around the edges no more H2O ! But water went in ballast and bulb but still having problems now wipers not Working! Should of buy a FORD🤬
rpmirage
08-31-2010 08:05 PM
slam33
10-19-2009 09:07 AM
mlyons321
08-15-2009 01:34 AM
2001Carerra
09-30-2008 10:49 AM
dminh01
03-28-2008 08:52 PM
Quick Reply: 2009 cayenne turbo s, water in headlight assembly, faulty control unit
