MS Access Database Recovery
Old 07-06-2016, 04:00 AM
Rawatsonika4u's Avatar
Banned
Default MS Access Database Recovery
Microsoft Access Database file gets corrupted due to the improper handling and system generated errors. So before using any recovery solution you should take a backup of corrupted database files. The backup file will help you in case of any damaged in originally corrupted Access database file during the recovery process. I would like to share a blog that provides easy manual steps for repairing corrupted MS Access files.
Read here easy manual steps for Access database recovery:- Fix Corrupt Access Database Files.
Old 07-11-2016, 07:16 AM
kid_kad's Avatar
Thumbs up How to repair Access database?
There're two ways to repair Access database: manually and by using professional tool. First you should try to repair Access database manually with the help of Compact and Repair utility, JetComp.exe and a manual trick for importing corrupt database into a new database. You can find a detailed information in this blog post: Repair Access Database with Compact and Repair Utility | N. Sem's Blog
You can also try a professional solution to repair Access database. Download free demo version of Access Database Recovery tool, and repair corrupt Access database files (MDB and ACCDB) with ease. For more information, you can visit: www.data-recovery-solutions.com/access-database-recovery.html
Hope the shared information would be helpful here.
Thanks and best regards.
Old 09-26-2016, 05:34 AM
Use the latest Access Recovery Tool that easily repairs corrupt MS Access (.MDB or .ACCDB) database file and then recover tables, queries, forms, macros, reports, etc. It also restores permanently deleted data from MDB file of MS Access 2013, 2010, 2007, 2003, 2002, 2000 on your latest Windows 8.1 PC & all below Windows version like as Win8, Win7, Vista, 2003 and XP.
Have a look at: MS Access Database Recovery Software to Repair corrupt .MDB files
Old 05-22-2017, 01:07 AM
chadkeane's Avatar
Banned
Access File Recovery to Repair Inaccessible MS Access Database File is an intelligent solution to fix all corruption issues in ACCDB and MDB database files and saves all the deleted records and objects like indexes, queries, relations and tables, on new database. In addition, the software supports calculated data type and linked tables. It also recovers encrypted modules and forms and compatible to MS Access 2016 and other earlier models.
Richard Smith
04-14-2022 12:31 AM
RalphHankins
12-11-2018 11:33 PM
Richard Smith
10-03-2017 12:36 AM
abelmartin002
06-23-2017 01:32 AM
Quick Reply: MS Access Database Recovery
