water pump
Old 01-17-2005, 03:34 AM
Gapowr99's Avatar
Default water pump
I think the water pump may be getting ready to hit the hay. I found one for 50 bucks new. but says fits up to 1986. is there a difference in the 87 one?
Old 01-17-2005, 11:17 AM
Default RE: water pump
Porsche did an upgrade on the waterpumps, starting in '87. Its a better design, but not by much, imo, and the old style should still fit. Where did you find a new water pump for $50?? Normally, they are around $220 new, and around $50 for a rebuilt one.
Regards,
Old 01-17-2005, 03:17 PM
Be weary of a cheap item. Was is aftermarket? If so did you research the company? And was there a warranty?
The last thing anybody wants is to be stranded along side the road due to a cheaply made water pump.
__________________________________________________ _____________________________
If you can see a 5 y/o's fingerprints on it and it says Made in China.... You might be at walmart
Old 01-17-2005, 06:00 PM
The big concern is that if the impeller shaft seizes, it can cause the timing belt to get thrown off, causing bent valves and a not so fun time dealing with the resulting damage. Since some of the rebuilt units floating around have been recycled a few times, they are getting near to a critical metal fatigue state, which makes the likelyhood of this happening go up some. Having said this, because I do my own work and can inspect the water pump before it goes on, I do use rebuilt water pumps on my 944's. My 951 and 968 both get new water pumps.
YMMV.
Gapowr, I thought you were buying a 951 engine? lol
Regards,
Old 01-17-2005, 07:58 PM
any 911 water pump from 85 - 88 will work
Old 01-17-2005, 11:56 PM
Trying to be funny, streetracer?
Regards,
Old 01-19-2005, 01:34 PM
Bump to bury another thread that has less value than this one...
Old 01-19-2005, 02:35 PM
Bump
kinderrich
03-02-2008 03:29 PM
milotype2
05-30-2007 05:15 PM
ZinFaren
03-15-2007 08:42 PM
sam un ont
01-26-2007 08:40 PM
confederatelowrider
08-16-2006 09:15 PM
Quick Reply: water pump
