early 85 water pump
Old Apr 24, 2007 | 09:36 PM
milotype2's Avatar
Default early 85 water pump
I'm hearing a "bearing" sound from behind the timing cover in the location of the water pump. I was going to replace the timing belt and balance shaft belt and all the rollers/tensioner anywaysince I don't know their age. The newer style water pump uses a guard rail and roller. Should I opt for the newer style? Is it an improvement? Any tips? Thanks
Old Apr 24, 2007 | 10:08 PM
Default RE: early 85 water pump
yes, i would recommend the newer style pump. You will have to cut out the back of the timing belt cover (rear one) to make it fit. You will also have to change to the larger idle roller for the timing belt, which would be done anyway during the belt change.
If you are hearing the bearing, then I would not start the car again, until after you have done the pump and bearings. A bearing seizes up, and your timing belt, and subsequently the valves, will be toast.
Old May 9, 2007 | 04:54 PM
milotype2's Avatar
Will a 86-87 turbo waterpump ( p/n 944 106 122.7)work if I bought the blockoff plate?
Old May 30, 2007 | 05:15 PM
milotype2's Avatar
Does anyone know the part # for the updated waterpump (belt rail studs) that will fit my early 85?
kinderrich
Mar 2, 2008 03:29 PM
ZinFaren
Mar 15, 2007 08:42 PM
sam un ont
Jan 26, 2007 08:40 PM
confederatelowrider
Aug 16, 2006 09:15 PM
Gapowr99
Jan 19, 2005 02:35 PM
