water pump
Old Jan 17, 2005 | 03:34 AM
Gapowr99's Avatar
Default water pump
I think the water pump may be getting ready to hit the hay. I found one for 50 bucks new. but says fits up to 1986. is there a difference in the 87 one?
Old Jan 17, 2005 | 11:17 AM
sh944's Avatar
Default RE: water pump
Porsche did an upgrade on the waterpumps, starting in '87. Its a better design, but not by much, imo, and the old style should still fit. Where did you find a new water pump for $50?? Normally, they are around $220 new, and around $50 for a rebuilt one.
Regards,
Old Jan 17, 2005 | 03:17 PM
Mr Pilkington's Avatar
Be weary of a cheap item. Was is aftermarket? If so did you research the company? And was there a warranty?
The last thing anybody wants is to be stranded along side the road due to a cheaply made water pump.
__________________________________________________ _____________________________
If you can see a 5 y/o's fingerprints on it and it says Made in China.... You might be at walmart
Old Jan 17, 2005 | 06:00 PM
sh944's Avatar
The big concern is that if the impeller shaft seizes, it can cause the timing belt to get thrown off, causing bent valves and a not so fun time dealing with the resulting damage. Since some of the rebuilt units floating around have been recycled a few times, they are getting near to a critical metal fatigue state, which makes the likelyhood of this happening go up some. Having said this, because I do my own work and can inspect the water pump before it goes on, I do use rebuilt water pumps on my 944's. My 951 and 968 both get new water pumps.
YMMV.
Gapowr, I thought you were buying a 951 engine? lol
Regards,
Old Jan 17, 2005 | 07:58 PM
Streetracer's Avatar
any 911 water pump from 85 - 88 will work
Old Jan 17, 2005 | 11:56 PM
sh944's Avatar
Trying to be funny, streetracer?
Regards,
Old Jan 19, 2005 | 01:34 PM
sh944's Avatar
Bump to bury another thread that has less value than this one...
Old Jan 19, 2005 | 02:35 PM
Me944's Avatar
Bump
kinderrich
Mar 2, 2008 03:29 PM
milotype2
May 30, 2007 05:15 PM
ZinFaren
Mar 15, 2007 08:42 PM
sam un ont
Jan 26, 2007 08:40 PM
confederatelowrider
Aug 16, 2006 09:15 PM
