Odd & Even fire V8
Old Jul 20, 2009 | 08:42 AM
Panzer's Avatar
Smile Odd & Even fire V8
I know the 928 engine fires every 90 degrees of crank rotation, so it would be 90,90,90 270 right? I was also told that the Ferrari engines are even fire motors? I'm very ignorant on the matter so someone please shed some light.
Old Jul 20, 2009 | 04:42 PM
Lee Willis's Avatar
Every piston fires every 720 degrees of engine rotation (once every two revs), so on a V8, you get 4 cylinders firing per revolution, which averages out to one combustion every 90 degrees of rotation.
If the crankshaft journals are offset - those for opposing cylinders are split a bit so that firing cycles are evenly spaced -- the split adjusts for the fact that the V shape is 90 degrees off (or in some V8's 60 degrees off -- then you get cylinder firings at evenly spaced 90-degrees of rotation times per revolution. Almost all American, German, English, and Japanese V8s use this type of crankshaft. It results in "even" firing.
Ferrari uses a "flat" crankshaft - the journals for opposing cyliners are not offset and in fact the journals are al 180s out of phase. As a result in a V configuration the cylinders fire four times per resolution but with a timing somewhat uneven. These crankshafts are used for a variety of reasons/excuses. They make more vibration but are stronger (some say) and lighter (probably true). I have not heard the term "odd" used for this firing cycle (this is not an even-odd thing, but an even-uneven thing).
If the difference seems confusing, think of the sound a Harley engine makes -- it is a V twin with no offset in the crank journals (like Ferrari) only just two cylinders, so the cylinders fire unevenly in time -- pow-short delay-pow-long delay- pow-short delay-pow-long delay . . .and so forth. Some big Japenese V twins don't make that uneven rythum because they use an offest crank journal for their two pistons. A Ferrari V8 is sort of like four of those Harley's bonded together, each pair having that uneven staccato sound. It doesn't sound like a Harley because of some other differences and because there are four sets of pistons feeding into two headers and it revs alot higher, etc.
Old Jul 21, 2009 | 09:00 AM
Panzer's Avatar
danka schoen. I'm studying an A.S.E. book but it doesn't have anything about this in it.
Old Jul 22, 2009 | 05:18 PM
Lee Willis's Avatar
Well, there is a lot you won't get by reading any one book. This is covered in several engineering books I have, and you certainly see it when you take apart, say, an GM LS6 V8 vs. a Ferrari 430 V8. (the Ferrari, by the way, isn't the better engine, just the more expensive. I actually like the Chevy more - a bit lighter, fewer parts, and with more stock HP and torque)
paolas
Nov 30, 2008 09:39 PM
buffsman
Oct 16, 2008 06:07 PM
Dude
Sep 20, 2008 11:22 PM
Ak01
Feb 25, 2007 09:24 PM
slyman
Sep 6, 2005 03:37 PM
