Oil Question
Hi buddy,
★★★★★ 4,8 Rating
Check PriceViscosity:
SAE: 5w-50
Specifications:
API: SN
ACEA: A3/B3, A3/B4
Approvals:
VW 501 01 / 505 00, Porsche A40, MB 229.3, 229.1
★★★★★ 4,8 Rating
SAE: 20w-60
★★★★★ 4,8 Rating
SAE: 5w-40
Specifications:
API: SN
ACEA: A3/B4, A3/B3
Approvals:
BMW Longlife-01, MB 229.5, 229.5, 226.5, Porsche A40, VW 502 00 / 505 00 / 505 01, Renault RN0700, RN0710, PSA B71 2296
★★★★★ 4,8 Rating
SAE: 5w-40
Specifications:
API: SN
ACEA: A3/B4
Approvals:
MB-Approval 229.5 / 226.5, PORSCHE A40, RENAULT RN0710 / RN0700, VW 502 00 / 505 00, PERFORMANCE LEVEL, BMW LL-01 <2019, CHRYSLER MS-12991, FIAT 9.55535-G2 / H2 / M2 / N2 / Z2, GM-Opel LL B-025 (Diesel), PSA B71 2296
★★★★★ 4,8 Rating
SAE: 5w-30
Specifications:
API: SP
ACEA: C3
Approvals:
BMW Longlife-04, MB 229.31, MB 229.51, Porsche C30, VW 504 00 / 507 00, Fiat 9.55535-S1, Fiat 9.55535-S3
Top 5 Engine Oil for Porsche Cayenne
Mobil 1 Advanced Full Synthetic Motor Oil 5W-50
Mobil motor oil provides excellent wear protection with excellent engine fuel economy benefits.★★★★★ 4,8 Rating
SAE: 5w-50
Specifications:
API: SN
ACEA: A3/B3, A3/B4
Approvals:
RAVENOL Racing 20W-60
RAVENOL Racing 20W-60 engine oil is ideal for gasoline engines for motor racing, even under the highest loads.★★★★★ 4,8 Rating
SAE: 20w-60
Valvoline European Vehicle 5W-40 oil
The full synthetic formula for exceptional high and low-temperature protection. Extra wear protection designed to help keep automotive engine parts like new.★★★★★ 4,8 Rating
SAE: 5w-40
Specifications:
API: SN
ACEA: A3/B4, A3/B3
Approvals:
Motul 8100 X-Cess 5W-40
The engine oil is designed for powerful and modern vehicles equipped with large displacement engines, direct-injection gasoline engines, and turbo diesel and catalytic converters.★★★★★ 4,8 Rating
SAE: 5w-40
Specifications:
API: SN
ACEA: A3/B4
Approvals:
Liqui Moly Top Tec 4200 5W-30
Liqui Moly TopTec 4200 5w-30 is an all-season synthetic engine oil for passenger cars running on gasoline and diesel fuel, including cars equipped with a particulate filter in accordance with Euro 4 standards and extended vehicle maintenance intervals.★★★★★ 4,8 Rating
SAE: 5w-30
Specifications:
API: SP
ACEA: C3
Approvals:
Porsche uses fully-synthetic high-performance engine oil from Mobil 1. I can recommend you Mobil 1 Advanced Full Synthetic Motor Oil 5W-50 for your 2005 Cayenne S. https://cararac.com/gear_oil/ - read this one if you want to find the best oil for Cayenne S. Good luck!
