2001 911 carrera 4 cabriolet
Old Aug 2, 2007 | 08:22 PM
sburkes's Avatar
Default 2001 911 carrera 4 cabriolet
i have a 2001 carrera 4 cabriolet with a convertible top problem. it will not close elecronically. i have checked the fuse and it's good. i can almost close it manually (won't go the extra 2 inches!!) any thoughts?////
steve22[&:]
Old Aug 3, 2007 | 12:50 AM
PorscheFreak$$'s Avatar
Default RE: 2001 911 carrera 4 cabriolet
Does it operate at all?
Is the deck lid open?
Is the e-brake light coming on?
Whats it saying on the instrument cluster ?Is the cab top light just flashing?
Moe
Old Aug 3, 2007 | 06:43 AM
wdonovan's Avatar
Does it operate with the door lock? Is the parking brake indicator light on?
Old Aug 3, 2007 | 06:53 AM
sburkes's Avatar
Default RE: 2001 911 carrera 4 cabriolet-follow-up info
Here's more info....
The parking brake in on and light is lit.
The top can be moved manually-top and lid.
The top indicator light is lit for open top after engine is started.
That light remains light after the hard top is installed and secured.
The deck lid is secured.
thanks for the replies..
Old Aug 5, 2007 | 05:58 AM
sburkes's Avatar
does anyone know the proper way to test the micro switches? ohm meter/voltmeter.
Old Aug 8, 2007 | 02:07 PM
theshagster's Avatar
check with both an ohm and volt meter
Old Aug 30, 2010 | 08:02 PM
gec19delta's Avatar
Default Top issues
Porsche cabriolet tops goes down fine top comes up it latches then release and latches and release with no locking and rear windows dont roll up correct ? Well on the car side of the latching mech there is a mico switch that pushes in use a small screwdriver and push it it while the lock is engaged . If it locks then release and that is it . If swith is damaged then the unit needs to be replaced but if this repairs the issue there is a quick fix cut a piece of plastic use some epoxy glue and glue it to the plastic patel that attivate the micro switch
mikelb6
Mar 19, 2008 11:56 PM
mikelb6
Feb 19, 2008 10:01 PM
sburkes
Aug 3, 2007 01:03 PM
anthraciteboy
Nov 12, 2003 08:14 PM
