911sc clutch issue
hi, i have a 1983 911sc cabriolet with 35k miles, just got out of storage and the clutch is acting up, or at least the cable is. when i release the clutch pedal it semms to almost stops releasing, still not engages, then you have to release the pedal a fair amount to continue and it grabs all at once, causing the car to busck severly or stall, once going all is fine, i hope its a bad cable or adjustment and not needind a new clutch, have read up on the cable and helper spring issue and hope that will remedt the situation. any thoughts? thanks bob
The cable could be sticking, and that would meen removing the cable and lubricating it.
It could also point to a problem with the clutch pressure plate diaphragm/springs hanging up, ora problem with the clutch relase bearing.
Lubricate the cable first.
Big Bob
Big Bob
