not running hot ???
I had some time to look at my motor today and i found that the plug to the auxilary fan was a little loose. I seated it and took it out for a little drive, she stayed rock steady at a healthy temp even through some hard acceleration. could this have been it? i also thought that one of my oil lines could have been clogged is this possible? I change the oil regularly. I just returned the air intake to stock from the air box to the mass air flow sensor. i had my ecm rebuilt as it had a after market chip in it which had failed. i will be replacing my starter as soon as it cools down here as well as some of the electron transport cables and grounding straps.
Are there any other intermittent causes of high temp?
