NSF to PST Conversion
Old Nov 30, 2015 | 03:50 AM
ramonvega's Avatar
Default NSF to PST Conversion
NSF to PST Converter is a very innovative tool to Lotus Notes users who need simple migration way from Lotus Notes to MS Outlook . This converter tool is developed by the professional programmers. It can transfer all NSF mailbox from Lotus Notes to Outlook platform. You can also save the converted NSF file in PST, HTML, TEXT and RTF format.
Features :-
>> Convert unlimited NSF files to PST
>> Support Unicode characters
>> Preview of converted files before saving
>> Supports MS Outlook 97, 98, 2000, 2002, 2003, 2007, 2010, and 2013 versions
>> Install on OS Windows 8.1, 8, 7, Vista, XP, 2000, 98, NT and 95
Know more :- NSF to PST Converter Tool to Convertâ„Exportâ„Import Lotus Notes Item to Outlook
Old Mar 1, 2016 | 06:46 AM
jsen's Avatar
Default NSF to PST file conversion
Convert NSF file into Outlook PST with advanced application released by eSoftTools. This is the smartest tool works on all versions and known for its brilliant performance about NSF to PST conversion. It allow to export NSF contacts in CSV file formats. Along with conversion of Lotus Notes data in multiple file formats like PST, EML and MSG.
Read More
NSF to PST Converter to Recover, View & Convert NSF to PST
Old May 7, 2016 | 07:12 AM
kid_kad's Avatar
Default How to convert NSF to PST format?
Instead of spending your money on any third-party paid tool, you should first try an easy manual trick that requires no cost at all. Just export Lotus notes data to such format which is supported by Outlook client, for example: structured text or comma separated value format. After that, you can import the new file to Outlook client by using its Import feature. See how easy it is without using any third-party paid tool. You can refer to this blog post for more information: An Effortless Way to Convert NSF to PST Format | N. Sem's Blog
Try it for sure. Hope it would be helpful for you.
Thanks and best regards.
Old May 23, 2016 | 04:38 AM
samirajoseph's Avatar
Default NSF to PST Converter
If you need to export NSF data into PST file then make use of eSoftTools NSF to PST converter software. This is the fastest tool for quick conversion of NSF file into PST, EML and MSG format. After converting NSF file database into MS Outlook users have choice to split PST.
Read More
http://www.nsftopstsoftware.esofttools.com/
Old Jul 29, 2017 | 07:39 AM
lucasdawson1984's Avatar
Learn the manual procedure of conversion from this article on How To Convert NSF File Into PST Format
This article describes the manual procedure as well as conversion tool procedure aptly and extensively.
Old May 30, 2019 | 02:34 AM
romanhuston's Avatar
Get the seamless NSF to PST Convert Tool which simply moves Lotus Notes files to Outlook Utility without Outlook but Lotus Notes is necessary to install. Try this application because it offers a remarkable feature that gives service during the method and even after the conclusion of migrator way.
For more info visit here: https://www.sametools.com/convert/nsf/
Rawatsonika4u
Jun 29, 2021 01:38 AM
kennycureton
Oct 4, 2019 07:48 AM
NicholasGonzalez
Jul 18, 2019 06:51 AM
