OIL LEVEL GAUGE
Old May 30, 2006 | 11:59 PM
BIBBER's Avatar
Default OIL LEVEL GAUGE
While it's fairly worthless the oil level gauge
in my 83 911 just zaps up and down crazily
driving my crazily...I've had enough but would
like to fix rather than disengage. Has anyone
else experienced this eradict behavior and
was it corrected with a new tank sending unit
or is it the gauge?.....THANKS in advance
Old May 31, 2006 | 12:36 AM
Default RE: OIL LEVEL GAUGE
You can try a new sending unit. The oil level gauge should only read when the car is not moving at idle and the engine is warm. When you are driving, typically it shows in the red, but some movement is normal.
Old May 31, 2006 | 11:28 AM
BIBBER's Avatar
Porschedoc
THANKS...the movement, however is not a gradual movement...the needle
literally pegs back and forth on the guage very quickly up and down and then
settles for awhile. That's why I'm not sure if it's the sending unit that's
wacko or the gauge itself.
Old May 31, 2006 | 12:21 PM
I would look to the sending unit first, sounds like it is coming apart, lol.
Old Jun 13, 2006 | 06:51 PM
BIBBER's Avatar
Replaced the sending unit...took care of the eradict gauge needle..
now reads steady after warmup...THANKS
Old Jun 13, 2006 | 10:38 PM
Sweet!
Pol-can
Nov 27, 2012 04:51 PM
o1marc
Feb 26, 2011 09:53 PM
godskritik
Jul 2, 2009 04:04 PM
q5ka
May 22, 2007 05:23 PM
pwb510
Oct 16, 2004 04:33 PM
