Split PST Tool
Old Oct 12, 2015 | 04:47 AM
jeffturner0007's Avatar
Default Split PST Tool
Split PST Tool software which can split large PST file in few mouse clicks with that has multiple splitting option and split file without data loosing.It uses its own PST splitter to avoid the risk of corruption of PST files due to the issue of being over-sized. Efficiently splits a large PST file into smaller and manageable PSTs, based on specified PST split criterion, such as Date, Size, Mail Id and Folder.
Read more :- http://www.recoverfilesdata.com/spli...file-tool.html
Old Jan 12, 2016 | 04:48 AM
matthewrenshaw's Avatar
Managing the large size Outlook PST file into small parts according to date, year, size, email ID and folder based. You can use of user-friendly tool http://www.pstsplitter.net which is well works on all MS Outlook versions.
Old May 6, 2016 | 04:38 AM
Rawatsonika4u's Avatar
Banned
Try another PST-Splitter tool to split oversize PST file into small manageable multiple parts. The tool perform splitting process in very safe mode without causing any change and damage. The tool also provide add on feature to Add new PST file in MS Outlook profile.
Read more advanced features and download free demo version here: Split Outlook PST File via Smart PST Splitter Tool
Old Nov 18, 2016 | 01:43 AM
fernandes's Avatar
Default Split to pst
If you are facing problem of splitting your file then use PST split pro .company sometimes needs to divide their task or file according to year or size or folder then this will be the best software which I am recommending you to use.https://www.split-pst.net/
Old Nov 21, 2016 | 06:45 AM
kid_kad's Avatar
Thumbs up How to split PST file into multiple smaller parts?
There are few easy manual tricks which can help you move or export mailbox data from one PST file into multiple new PST files. Instead of using any such paid software, you must try the free manual tricks. If you're trying the manual tricks, there's no need to use any paid software. All you need to use is Microsoft Outlook client. It has few built-in features and functions which you can use here. I can share this blog post here in which you can find the complete information: Easy Way to Split PST File into Multiple Smaller Parts | N. Sem's Blog
If the manual tricks fail or don't work for you, then only you should consider using professional PST Split software. It can safely split PST file into multiple parts without causing any changes or alteration. It provides you different options to split PST file, such as: split by size, split by date and split by senders' email IDs. You must try its free demo version first. If you're satisfied with the results, then you can purchase the software. I hope the shared information would be helpful here.
Thanks and best regards.
Old Nov 24, 2017 | 03:37 AM
amazsilong's Avatar
Default split pst
There are multiple solutions are available that Splits PST files into smaller ones. This helps to prevents file corruption. I found few solutions that can easily split large sized pst files into small outlook data files. Split by year, date and size is possible with multiple tools. I used this utility when my outlook was slow and facing memory issue. I used this tool http://www.osttopstapp.com/split-pst.html
Old Apr 2, 2018 | 02:54 AM
Max Jordan's Avatar
Try Revove PST Splitter software to easily break multiple Outlook PST file into smaller file formats. The software provides multiple advanced options to split Outlook PST file without losing any data. You can also split PST by
  1. Split by Size
  2. Split by Date
  3. Split by Year
  4. Split by Folder
The software is compatible with all version of Microsoft Outlook i.e. 2016, 2013, 2010, 2007. Download Revove PST Splitter software now for a free trial.
Old Apr 23, 2018 | 01:51 AM
sentluis31's Avatar
Go to http://www.recoverydatatools.com/outlook-pst-recovery.html and download demo version of MS Outlook PST recovery program for the recovery of MS Outlook PST files.
Old Nov 13, 2019 | 01:39 AM
jennifershine15's Avatar
Default Split PST Files
If anyone wants to split the large PST files into single PST files then I would suggest trying to use the KDETools PST Splitter. It breaks the large PST file by date, size, year and folder according the needs. It supports without installing MS-Outlook. This tool supports all the Windows Version and Outlook Version. This tool split the large unlimited PST files easily.
More Details: Split PST Tool to Divide/Split Large Outlook PST File into Smaller Parts
Old May 25, 2021 | 11:49 PM
  #10
AKASH's Avatar
I suggest downloading a free trial version of Split Outlook PST if you are looking for a secure and easy way to split a large PST file into several small PST files. This free tool will show you how to break an oversized PST file into many smaller ones. Split PST files by date, size, folder, and are just a few of the options available with this tool.
